Instent Mesh with an Uplink from each side
hi team,
how can i get a mesh , if i have a switch connected to each AP , the idea is to share the wired connection via the Instant AP.
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Instent Mesh with an Uplink from each side
Have you seen the article here? http://community.arubanetworks.com/t5/Controller-less-WLANs/Aruba-Instant-4-1-Mesh-Configuration/ta-p/214943
i have seen it ,and it do not answer my question i need to use mesh to bridge the wired connection.
Raouf CHAHBOUNE
Do you have the mesh already setup, then?
Okay.  Look at this article here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-configure-wired-bridging-over-a-mesh-link/ta-p/181020
Please search the Airheads Knowledgebase before posting, because it will save you alot of time:  http://community.arubanetworks.com/t5/Support/ct-p/Support-Documentation-Downloads
