Contributor I
Invalid Device Serial Number when adding whitelisted AP
Hi guys,
Have anyone of you encountered the said error as title above?
Airwave is running in version 8.0.7.1 now.. this error was only seen when we tried to whitelist AP205H with its serial number into the airwave. It is working when using its LAN mac address.
error
Please advise.
Re: Invalid Device Serial Number when adding whitelisted AP
Are you using Aruba Activate?
Contributor I
Hi Colin,
nope.. it just normal AP whitelisting in specific group.
I already got the answer from support. My current version AMP 8.0.8.1 does not allow to add devices with ten digit serial numbers.
Thanks.
