Is it possible to block VLANs / IP ranges for SSIDs using the Aruba IAP-205 VC interface?
We have 150+ Aruba IAP-205 access points in VC clusters for each site using different subnets.  We are looking to setup a guest network to only allow HTTP and HTTPS access.  I found a guide to help setup everything you will need to accomplish this.  I have the Guest SSID working but I don't want end users to be able to type in IP's of servers via HTTP / HTTPS.
Granted, it takes them to a login screen for that service (content filter, spam filter, etc.) but I would rather they get nothing.
Here is what I currently have configured for Access in this order:
  • Allow dhcp to all destinations + log
  • Allow dns to all destinations + log
  • Allow http to all destinations + log
  • Allow https to all destinations + log
  • Deny any to all destinations
I was hoping I could block our server's at the bottom of the list via VLANs or IP address range.  I didn't see anywhere to do this.
Thanks, experts.
Re: Is it possible to block VLANs / IP ranges for SSIDs using the Aruba IAP-205 VC interface?
When you're building your firewall policies, you should see a network and host options in the destination drop down.
Tim Cappalli | Aruba Security
That was it.  Glad it was an easy solution.
Thanks for the help.
