Is it possible to delete AppRF data?
We have been testing Aruba IAPs with our development and IT teams for the last few weeks and will be going live for the entire company tomorrow night. Is there some way to delete all of the data in AppRF so we can start fresh on Wednesday morning?
Contributor II
Re: Is it possible to delete AppRF data?
If you dont have Airwave deployed, AppRF only retains data for the last 2 minutes.
Jibran Aziz
ACDX | ACCP | ACMP | ACMA | CCIE (RnS, SP, DC) | JNCIS | JNCIA
Thank you Jibran, we are using Airwave on Aruba Central and I see all of the data since the day we started testing.
Brad
Contributor II
Hi Brad,
Your best bet will be to contact TAC for this one.
One solution I can think of is to reduce AppRF retention period to 1 day (under AMP Setup). On the day your services are live, you can change it back to 30 days or number of days you want to retain the data.
Jibran Aziz
