Is it possible to design a mesh work with Power ethernet?
I would like to make a mesh network with 225IAP, but i don't know why it dosen't works. I connect all of them in a switch to take the config wihile wired. Then I rebot one of them without wired connection but it dosen't take the config from VC.
Do you know the problem is because I connected all of them in a Poe adapter? Can the APs works in a mesh system with POe adapters?
Thanks for all,
Re: Is it possible to design a mesh work with Power ethernet?
Mesh is currently not supported for the AP225
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Valued Contributor I
Mesh is coming to the AP-22x / -27x later this year.
Any updates on when mesh will be supported on the 225?
