Regular Contributor I
Is it possible to have captive-portal in http in Instant AP?
Is it possible to have the internal captive-portal in http in IAP?
Re: Is it possible to have captive-portal in http in Instant AP?
Only if you are using an external captive portal.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Can i get around with installing a public signed certificate for captive-portal in the instant?
Yes, that would take care of the error.
