Is there a dummies guide for setting up a guest network?
Setting up a production network for our new IAP-215 was pretty painless but I can't figure out how to set up a network for our guests.
I'm using virtual controller assigned IP which is fine but when I connect my test client, our internal DNS server is listed. If I block all access to our 10.0.0.0 network then the guest client can't resolve addresses.
Help. I'm a dummy.
Re: Is there a dummies guide for setting up a guest network?
Are you allowing internal dns before blocking all the internal space?
Tim
Tim Cappalli | Aruba Security
permit dns to anywhere, then block access to 10.0.0.0
Well that was easy. Thanks. I guess I was over thinking it and under thinking it at the same time if that's possible. Told you I was a dummy.
