Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
Excuse me i this is not the right place to post this question - it is my first time.  I'm wondering if it is possible to enable and disable my guest wireless ssid automatically depending on time of day.  This is my current version.
ArubaOS (MODEL: 105), Version 6.3.1.4-4.0.0.6
Website: http://www.arubanetworks.com
Copyright (c) 2002-2014, Aruba Networks, Inc.
Compiled on 2014-06-05 at 09:52:43 PDT (build 44126) by p4build
Trusted Contributor I
Re: Is there way to enable - disable an ssid by time of day using virtual controller and AP-105
this is totally the right place.
unfortunately this isn't possible with the Instant software. if you are good enough with scripting you might be able to build something on another system, but that is it.
If you have AirWave, you can schedule it there.
Tim
Tim Cappalli | Aruba Security
Thanks for your reply - I am checking into airwave to see what that is all about.
