JL184A - IAP-205-RW
Will a HP JL184A work in the same cluster as an Aruba IAP-205; and do they run the same firmware?
Re: JL184A - IAP-205-RW
The short answer is no, because they run different firmware...
Ahh, thanks Colin,
Can they be converted with Aruba firmware or would it be the same problem as converting a Dell one?
