Frequent Contributor II
Limiting users in IAP
Is there a way to limit the client per IAP, [like 20 users per IAP].
We are using IAP 105 with CPPM.
rana
Valued Contributor II
Re: Limiting users in IAP
Hi Rana,
It is possible to set the threshold for the Clients. we can set the value in "Wlan settings --> Advanced settings" . we can set the value from 1-255 and the default value will be 64.
You can refer IAP User Guide for this feature.
For your ref :
Please feel f ree for any further help on this.
Cheers,
Venu Puduchery,
just to clarify:
the limitation is per Radio  Per SSID
so for exemple
if you limite the user number to 64 , you can go to 64 users in 2.4 Ghz and 64 users in 5 Ghz  (a total of 128)
and don't forget it is per SSID
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
