MST200 (MST2HAC-US) wont power with PoE Injector PD-9001GR-AC
We purchased the MST2HAC-US &  PD-9001GR-AC PoE Inojector and the Access point's won't power up.  I understand the MST2HAC is the powered version but Aruba Tech support said that model can still run with PoE.  we've tried two AP's and Power injectors and none of them power.  Any suggestions?
Re: MST200 (MST2HAC-US) wont power with PoE Injector PD-9001GR-AC
Unfortunately, that model can only be powered via AC.  It provides 802.3at power OUT, however.
