Frequent Contributor II
Max amount of roles in a instant cluster?
Hi!
Does anyone know what is the maximum configurable amount of different roles on an instant?
Thanks a lot!
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Re: Max amount of roles in a instant cluster?
Hey, i took a quick look at the 6.4.4.3-4.2.2.0 user guide and Instant allows you to configuration of up to 32 user roles. If the number of roles exceed 32, an error message is displayed.
Haven't tested this myself however...
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
