Mesh Portal and Point (point-to-point)
  • 1.  Mesh Portal and Point (point-to-point)
    Posted Oct 05, 2016 03:52 AM
    I'd like to know IAP 270 series to run mesh portal and point, as described at http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/Mesh_Instant_Access_Poin.htm
    Questions:
    1. Do I need to use external controller/additional license to run mesh portal and point? or the current IAP OS can handle.
    2. Between offices with point-to-point, around 300meters, line of sight with IAP 270 series, any suggestion for choosing antenna?
    Thanks.
  • 2.  RE: Mesh Portal and Point (point-to-point)
    Posted Oct 05, 2016 04:21 AM
    1.  No licenses.  The IAPs do not require them.
    2.   Please see the ordering guide here:  http://www.arubanetworks.com/assets/og/OG_AP-270Series.pdf  The 5314 is a candidate on the face of it because it is a high gain sector.
    You should engage an experienced consultant to find out what is the correct antenna and to understand if your physical setup is a candidate for mesh at that distance.  More information can be found in the VRD here:. http://community.arubanetworks.com/t5/Validated-Reference-Design/Outdoor-MIMO-Wireless-Networks/ta-p/155624
