Mesh function of IAP275
Hi,All
I want to connect remote two spots by outdoor radio in Mesh.
In IAP275, is mesh connection supported?
When it is done, which version is it?
When are you supported?
I want you to tell me.
Regards
Re: Mesh function of IAP275
It will be supported in the next version of code.
Tim
Tim Cappalli | Aruba Security
Thanks a lot Tim !
