Mesh on 2.4 GHz
Mesh with two IAP-277 on 5 GHz Band is unstable due to radar activity nearby.
Is there a possibility to mesh on 2.4 GHz?
6/28/2017 12:40:27 PM Target: AP01 Command: show ap arm history
Interface :wifi0
ARM History
Time of Change Old Channel New Channel Old Power New Power Reason
2017-06-28 11:36:00 116E 100E 30 30 R
2017-06-28 11:35:08 100E 116E 30 30 I
2017-06-28 10:58:14 116E 100E 30 30 R
Re: Mesh on 2.4 GHz
If this in instant, unfortunately mesh is only available on the 5ghz band.  Are you forced to use DFS channels because of your regulatory domain?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Mesh on 2.4 GHz
Yes, Germany Outdoor
Re: Mesh on 2.4 GHz
Try to do 20mhz channels, instead of 80mhz channels.
Re: Mesh on 2.4 GHz
I am saying that because you could be seeing a false positive, and those are less likely to happen on 20mhz channels in my experience.
