Mesh with IAP 275 quesstions
hi,
I'm going to configure a mesh link with 3 IAP 275 and I Have some question:
1. What is the average distance between two IAP (in open area).
2.Can an IAP configured as a mesh point, bridge the signal to another IAP (another mesh point).
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Mesh with IAP 275 quesstions
Mesh isnt supported yet on the 275's
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you for the replay,
yes i just get the confirmation from Aruba TAC.
Raouf CHAHBOUNE
For the refernce
 the IAP
  • 224 / 225
  • 274 / 245
  • 204 / 205
  • 214 / 215
Do not support the Mesh yet , so be careful :)
Regards
Raouf CHAHBOUNE
Super Contributor II
Hi!
From what I´ve heard the functionality should be available in Instant OS 4.2. Anyone have information about when it will be available?
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
from what i've heard it is under test.
there are no official date.
Raouf CHAHBOUNE
Occasional Contributor I
Any updates? I choose Aruba radios over Ruckus because of their ability to be controller-less. Ruckus radios are mesh capable but with a controller.
Mesh is currently available on the controller platform. Controllerless (Instant) is expected to be available by the end of June. Please contact your Aruba rep for more info.
Tim
Tim Cappalli | Aruba Security
Thank you Tim for the very quick reply.
I logged a call to Aruba TAC to see when the wireless mesh fuction will available for the IAP-2xx series. From memory it was July. I had access to the beta and can confirm i have 2 x IAP-274s wirelessly meshed and working very well.
