Minimum number of IAPs requirement for Rogue AP detection.
              With Aruba Instant AP is there any limitation on the minimum number of IAPs that should be present in a cluster to effectively detect Rogue APs.
Tuhin
MVP
Re: Minimum number of IAPs requirement for Rogue AP detection.
:smileyhappy:
It's depends if one unit cover all your client location.
If just 1 unit cover all his location with RF (in 2.4 & 5)  - so yes , one it's enough.
(i usually like put 2 Accesspoint  in opposite walls. (1+2=3) but again,it's all depends on the size of your client site.)
Me.
MVP
PCI requires rogue detection in our point-of-sale, so we hang one in the vicinity of our checklanes (replacing the AP65 currently in place)
We set it up in monitor only mode for full-time WIPS, but it gives us a VC in the store so we can add 10-12 more iAP units later to cover the store with WiFi and extend the WIPS store-wide when they're not servicing clients.
One is not only enough (if it can see the required airspace) its a great start!
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
