Occasional Contributor I
Missing EIRP Restriction. Users can configure EIRP beyond the Max EIRP.
In the firmware 6.5.0.0-4.3.0.0, the aruba WAP allows users to set EIRP which can exceed the defined MAX EIRP. For ex: when MAX EIRP is set to 13dBm, it allows us to set the EIRP upto 15dBm.
The below log shows the MAX EIRP and the current EIRP:
18:64:72:c8:4f:ac# a-channel 149 15
18:64:72:c8:4f:ac# show ap bss-table
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t
18:64:72:04:fa:d3 xbu15_test4 ?/? 172.29.15.225 a-VHT ap 149/15/13 0 18:64:72:c8:4f:ac 0 47m:52s
18:64:72:04:fa:c3 xbu15_test4 ?/? 172.29.15.225 g-HT ap 11/5/13 0 18:64:72:c8:4f:ac 0 48m:25s
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:2
Num Associations:0
18:64:72:c8:4f:ac#
This is a bug in the latest aruba software release which is a violation of EU regulation. Can someone confirm and look into it?
Re: Missing EIRP Restriction. Users can configure EIRP beyond the Max EIRP.
AP model and country?
Jerrod Howard
Sr. Techical Marketing Engineer
AP Model: 225
Country Code: Canada
More details below.
18:64:72:c8:4f:ac# show running-config | include country
virtual-controller-country CA
18:64:72:c8:4f:ac# show version
ArubaOS (MODEL: 225), Version 6.5.0.0-4.3.0.0
Website: http://www.arubanetworks.com
(c) Copyright 2015 Hewlett Packard Enterprise Development LP.
Compiled on 2016-09-12 at 03:25:40 PDT (build 56428) by p4build
FIPS Mode :disabled
AP uptime is 45 minutes 24 seconds
Reboot Time and Cause: AP rebooted Sun Dec 4 15:20:58 UTC 2016; CLI cmd at uptime 0D 0H 22M 36S: reload
18:64:72:c8:4f:ac#
Thank you.
If the regulatory limits have changed recently, you would need to grab the latest IAP version of code to be in compliance. I have asked our regulatory team as well, but 13dB sounds low for ch149 to be the max.
Jerrod Howard
Note that it is weird to see the setting at 15 when the noted max is 13, I would open a TAC case (nothing will get fixed or officially addressed here on this forum).
Jerrod Howard
Actually 'm thinking this is a misconfig. If you set the ARM value to X up to 13dB, but then you manually set it to 15, you are over-riding the min/max ARM setting. The regulatory max is well over 13 of course, but you should open a TAC case to make sure this is addressed in your situation, as you have the first release of a major bracnh of code. If there's a bug, it's likely already addressed.
Jerrod Howard
Hi Jerrod,
I was running a negative test case that's when I noticed this bug. As per your advice, I upgraded the software version to 6.5.1.0-4.3.1.1 where this issue is no longer seen.
I will continue using this verson henceforth. Thank you for your help.. Really appreciated.
Shiva
