Mixed class cluster split when promoting IAP325 to Master
  • 1.  Mixed class cluster split when promoting IAP325 to Master
    Posted Nov 27, 2016 11:01 AM
    I have came across strange behavior of a IAP mixed class cluster (30 x 215 & 1 x 325). After upgrading both classes of IAPs to have the same Instant OS version 6.4.4.8-4.2.4.3_56707 we were able to form a cluster with one of IAP215s as a master and IAP325 as a slave.
    But when we promote IAP325 to become a master, it leaves the cluster. When we turn off 'preferred master' option on IAP325, reboot it, it again joins the cluster as a slave.
    Anybody has any suggestions? Should we open TAC case?
  • 2.  RE: Mixed class cluster split when promoting IAP325 to Master
    Posted Nov 27, 2016 04:38 PM
    What version are you running ?
    Get Outlook for iOS
  • 3.  RE: Mixed class cluster split when promoting IAP325 to Master
    Posted Nov 28, 2016 02:29 AM
    Instant OS version 6.4.4.8-4.2.4.3_56707 (ED) on both IAP classes
  • 4.  RE: Mixed class cluster split when promoting IAP325 to Master
    Posted Nov 29, 2016 04:46 AM
    Type "show log system" and "show swarm state" on the IAP-325 commandline to get a clue what could be happening....
  • 5.  RE: Mixed class cluster split when promoting IAP325 to Master
    Posted Nov 30, 2016 02:27 PM
    Please see attached belowe two cmds from IAP325 which leaves the cluster when promoted to Master.
    Thank you in advance for your input.
    Attachment(s)
    txt
    show_log_system.txt   4 KB 1 version
    txt
    show_swarm_state.txt   575 B 1 version
