Regular Contributor II
Mobility
What is the difference between l2 and l3 mobility?
Thank you.
Re: Mobility
Please see the user guide chapter here for a complete explanation:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Mobility/Mobility.htm
In short, L2 mobility is roaming between two access points on the same VLAN without having to re-dhcp.  L3 mobility is usually roaming between two controllers and maintaining your ip address and sessions without having to re-dhcp.
Re: Mobility
Can i use two vlan in l2 mobility?
Re: Mobility
What exactly do you want to do?
Re: Mobility
Colin, I just want to know the difference between them .
Re: Mobility
L2 Vlan mobility happens pretty much automatically in the Aruba controller.  You can roam from access point to access point and keep your ip address.
L3 Vlan mobility needs to be setup so that a user can maintain an ip address between two controllers even though the second controller does not have the user's VLAN defined on it.
Both of these methods use a single VLAN.
I hope that helps.
Re: Mobility
Thank You Colin.
