Mount kit to use for these ceiling tiles?
Hi All,
Basic question, but I was just wondering which type of mount kit we should use for external mounting on ceiling tiles as per the attached picture.
There seems to be a number of options - just want to make sure we get it right.
The client is considering  IAP-103s, IAP-105s or IAP-115s at this stage.
Thanks for any help!
Re: Mount kit to use for these ceiling tiles?
The smaill tile adapter that is included should work, but you should measure.
Two ceiling rail adapters for 9/16” and 15/16” rails are included.
Tim Cappalli | Aruba Security
