Occasional Contributor I
My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
hi expert ,
anyone can help me to fixed this problem?
Re: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
Instant APs will only join other Instant AP clusters. The only relation
with a mobility controller would be a VPN connection which would need to be
manually configured.
Tim Cappalli | Aruba Security
Hi Tim,
Means, it cannot discover by itself? can you give me flow how to do it? i having problem that, posible i must downgrade my AP instant 105 aruba?
tq for your fast reply.
Are you trying to set up an instant cluster or do you want the IAP-105 to
work as a normal controller AP?
i want the IAP-105 to work as a normal AP. and connect to wireless controller aruba 2400 model. the problem is, i cannot discover the IAP-105 in Aruba 2400 Model Wireless Controller.
Go to the IAP GUI by connecting to the instant SSID and then going to
instant.arubanetworks.com in the browser. Then go to Maintenance > Convert
then select Campus APs managed by a mobility controller from the drop down
box.
Moderator
An IAP can be converted to a Campus AP and Remote AP only if the controller is running ArubaOS 6.1.4 or later.
Unfortunately, your 2400 can only run up to AOS 5.x.  As such, it cannot utilize IAPs as Campus APs.
it is ok? when in different os?
Hi Mr Marcus,
So the solutions is? i must downgrade my IAP 105  to 5.0.0 version and can discover by wireless controllet 2400 model 3.4.0 version? it is ?
The IAP cannot be downgraded to 5.x code.
