Need for firmware update?
Hello all,
When do you decide a firmware update for your IAP's are necessary?  We're currently on version  6.4.4.4-4.2.3.2 with just over 300 AP's and everything is working great. We don't have a need for any new options and from what I can tell at www.arubanetworks.com/support-services/security-bulletins/ there's no security reason we would need an update. Just curious how others go about deciding if when they would update.
Thanks for the space!
Re: Need for firmware update?
You are doing it right.
You should only update the firmware to fix a bug, to patch a security issue, or to get a new feature that is important to you.
