Need help securing and seperating corporate and guest networks
  • 1.  Need help securing and seperating corporate and guest networks
    Posted Nov 23, 2012 11:48 AM
    First, I just do tech support for client machines, but I have been tasked with setting up a few IAP-105s for our new WLAN. I am having issues keeping the guests off of the corporate network. My network is setup as follows.
    Corporate:
    networks: 192.168.x.x and 10.x.x.x (no WLAN on 10.x.x.x network.)
    Vlan: 1
    Guest:
    network: 172.16.20.x
    gateway: 192.168.20.1
    Vlan: 2000
    With the way I have things setup, the 172.16.20.0 can ping the 192.168.x.x network, but the 192.168.x.x cannot ping the 172.16.20.0 network. I don't want them to be able to send any traffic each other. Is the virtual controller somehow bridging/routing the traffic, or do I have to setup ACLs? The below is the current configuration. Any other suggestions for tweeking the config would be helpful as I am new to all this.
    Thanks.
    version 6.1.3.0-3.1.0
    virtual-controller-country US
    virtual-controller-key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    name IAP_1
    virtual-controller-ip 192.168.x.x
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap xx:xx:xx:xx:xx
    arm
     wide-bands 5ghz
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode fair-access
     client-aware
     scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user xxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan access-rule default_wired_port_profile
     rule any any match any any any permit
    wlan access-rule Guest
    wlan access-rule Corporate
    wlan ssid-profile Guest
     index 0
     type guest
     essid Guest
     wpa-passphrase xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
     opmode wpa2-psk-aes
     max-authentication-failures 3
     vlan 2000
     set-role-pre-auth Guest
     rf-band all
     captive-portal disable
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     air-time-limit 20
     blacklist
     dmo-channel-utilization-threshold 90
    wlan ssid-profile Corporate
     index 1
     type employee
     essid Corporate
     opmode wpa2-psk-aes
     max-authentication-failures 0
     vlan 1
     rf-band all
     dtim-period 1
     blacklist
    enet-vlan guest
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
     wireless-containment none
    ip dhcp Guest
     server-type local
     server-vlan 2000
     subnet 172.16.20.0
     subnet-mask 255.255.255.0
     lease-time 14400
     dns-server 8.8.8.8,8.8.4.4
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan 1
     native-vlan 1
     no shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex auto
     poe
     type employee
    wired-port-profile Guest
     allowed-vlan 2000
     native-vlan 2000
     no shutdown
     access-rule-name Guest
     speed auto
     duplex auto
     poe
     type guest
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
    l3-mobility
    #3600
  • 2.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 23, 2012 01:20 PM
    In the guest role you would simply block any traffic to the networks that you don't want users to get to.  The only exception would be for DNS if you are giving users an internal DNS server address.
  • 3.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 23, 2012 02:32 PM
    I added new guest ACL and it does block the traffic. I was not sure if it was not supposed to bridge the traffic over different subnets automatically or if I had something not setup in my config correctly.
     rule 192.168.0.0 255.255.0.0 match any any any deny
     rule 10.0.0.0 255.0.0.0 match any any any deny
    Are there any other tweeks that I should make reguarding security?
  • 4.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 23, 2012 03:25 PM
    That looks correct based on the information you provided.
  • 5.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 26, 2012 11:44 AM
    Would it be advisable to setup a GRE tunnel to a CISCO router for the guest network? Would this further help keep the guests from accessing the corporate network?
  • 6.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 26, 2012 02:22 PM
    It will not provide more protection.  Every packet goes through the access points' firewall and anything that needs to be dropped as per your rule, will be dropped at the access point promptly.  That is the advantage of an integrated firewall.
  • 7.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 26, 2012 08:05 PM
    Thanks. Is there anything else that I should do to seucre the AP?
  • 8.  RE: Need help securing and seperating corporate and guest networks
    Posted Nov 26, 2012 08:16 PM
    Strong admin password ;)
