Yesterday I registered an Aruba Central trial account. I added an existing two AP IAP cluster through the Device Management function and added it to a group and assigned 2 of the 5 trial licenses to the APs. Then I configured a new SSID and some settings and it all seems to work fine.
Then I connected two additional APs to the same subnet, after a few minutes they joined the cluster and I all four now seems to work fine and I can see all 4 APs in Aruba Central.
The problem is that the last 2 APs are not showing up under Device Management, I can only see the first 2 APs here. And when i try to add them manually by "Add Devices" I just get a "Failed to add device" error. They also don't show up so that I can add a subscription to them. Looking under Maintenance/Firmware shows that I have a Cluster with 4 APs, and all 4 APs also show up under Monitoring and Wireless Configuration/Access Points.
How do I get the missing 2 APs to show up under Device Management and allow me to assign a license?
