No Instant clients in Airwave
Hi, I'm deploynig AirWave 8.2.3.1 as monitoring system for two vendor wifi deployment. I've connected Juniper WLC controllers with about 500 of AP's (read-only mode) and is't woring fine. Now I'm connecting IAP's 103 and I'm able to manage it, but I do not see IAP client's in AirWave - IAP and VC always shows 0 clients. Any help where to start debuging?
Regards
Re: No Instant clients in Airwave
What method did you use to join the APs to Airwave?
Aruba Activate provisioning rule. Then I'm moving the AP to different folder manually to distinguish VC and IAP itself. But the issue is also for manual AW provisioning.
Are you seeing client information for controller based APs in Airwave?
Does Prefer AMON vs SNMP Polling is enabled in AMP Setup > General page>Additional Service section? If it set to disable can you enable and check the status.
Could you share the APs/Devcies>montior page of the VCs if data still not updating after enabling setting.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
I've enabled Prefer AMON, but it's still not collecting clients stats. Does Instant support AMON anyway?
I've added fesh IAP just for test, and behaviour is the same - does not show iap clients. Clients are reported from Juniper WLC.
Regards
Sorry! Ignore this :) Was already asked..
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
We need to check swarm debug or IGC logs in Airwave to debug the issue.
If you are OK, try restart all the Airwave services once and check the status.
Command to restart services
#rd
Airwave will take couple of mintues for all services to comeup during that time, GUI is not accessible.
If issue still persist after restarting the serivces, please open TAC ticket.
Pavan
Pavan
