Not seeing an IAP connect to device.arubanetworks.com
I'm playing with Activate and  trying to automate conversion of an IAP to a RAP.   I see the IAP boot and query for the NTP pool and then query for device.arubanetworks.com (which resolves).   I don't ever see any connection attempts (looking at the upstream firewall).   I can look at the log on the IAP and see it says something to the affect of "can't make connection to device.arubanetworks.com:443".
Ideas?
Re: Not seeing an IAP connect to device.arubanetworks.com
What version onf instant is it running?
Colin Joseph
Aruba Customer Engineering
What version of IAP are you using ?
Make sure it is the latest GA version or the latest ER version , there's an issue with a cert if you are running an older version
Thank you
Victor Fabian
Lead Mobility Architect
Hi all,
* Cancelled *
Can you share the output of CLI commands "show log provision" and "show log ap-debug" on this thread?
