SW Version: 6.1.3.4-3.1.0.2_36584
We have got IAP-134. When I use this for performance tests, I'm seeing very bad numbers.
We are testing with 1x1, in 2Ghz & 20Mhz is the channel bandwidth. We are seeing Tx bandwidth of iAP-134 hovering around ~51 Mbps. Where as already existing Cisco AP1252 is giving 63Mbps consistently.
When we saw the captures, the problem we saw was the aggregation was not happening properly. i.e. we see hardly 4 packets getting aggregated, not more than that. Where as with Cisco AP-1252, we saw around 11-12 packets getting aggregated with same client device.
I'm using the product OOB configuration. Only configuration we have done is channel, created SSID through GUI & configured IP.
Both AP, back-end chariot endpoint & wireless station are in same subnet.
Any help?
