VS
Occasional Contributor I
On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
I have not yet deployed an IAP-275, but we are installing one for a customer.  In the installation guide, it states that "The WAN port supports 802.3at Power over Ethernet (PoE), accepting 48 VDC (nominal) as a standard defined Powered Device (PD) from a Power Sourcing Equipment (PSE) such as a PoE midspan injector."  Does this mean that ONLY the WAN port will accept POE+ and, therefore, I should plug the ethernet cable from my switch into the WAN port instead of the LAN port?
Re: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
Eth0
Tim Cappalli | Aruba Security
VS
Thanks for the speedy response. Is Eth0 labeled as such on the IAP-275? Our installers are currently mounting the hardware, so I don't physically have it to look at.
MVP
Here's a photo of the one on my lab-bench right now:
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
VS
Outstanding. I could not find a good picture to reference. The installation doc only says "WAN" and "LAN". Many thanks to you and cappalli.
Hi Guys Does anyone know where I can get the installation guide for the iAP275? Thanks Mike
Thanks!
If I connect WAN port to a switch with PoE,
Can i connect LAN port to any IP Camera (to power up the IP Camera) and transfer data from IP camera passing through 275 to the switch.
