Frequent Contributor I
Option 43 for IAP to connect to Airwave
We can connect IAP to an Airwave Server by using DHCP Option 43 automatic and the IAP generates the given Group if they do not exist. On the Manuals i find the following String " ArubaInstantAP, tme-store4, 10.169.240.8, aruba123".
In this example "tme-store4" is the Group that will be created.
My Question now, is it also possible to generate a Folder also? If yes, what is the necessary syntax?
Thank you
Aruba
Re: Option 43 for IAP to connect to Airwave
The organization string will also create the folder/subfolder as well.
For example, the org string Acme:East:Boston will create these nested folders in Airwave
Acme
   - East
         - Boston
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Hello, thank you for that Information. If i use the Option on a IAp 105 as discussed, i can see that the AP with Release 6.2 receive the Option but does not Lease the IP Adress. With older Releases it has worked.
Do anyone know this behavior?
Thank you and best Regards
Are you also handing out option 60 ArubaInstantAP in the offer?
I seem to recall an IAP not taking a lease if this is not offered along with option 43.
/s
