Outdoor IAP with Wireless Backhaul
Is it possible to do wireless backhaul with a single IAP or does this require an Aruba AP, router or controller downstream?  In a situation where a client has another vendor's AP already installed, is it possible to do 802.11ac outdoors with an Aruba IAP or is it necessary to install two IAPs or a controller based solution?
Re: Outdoor IAP with Wireless Backhaul
You need either (1)  two Aruba Instant APs or  (2) two Aruba Campus APs with a controller.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Generally you need two of the same vendor's APs to do a mesh link/wireless bridge. If the other vendor's device supports 'client bridge mode', then you may be able to get away with just one Aruba AP/IAP and convert the other device to a client bridge.
Jerrod Howard
