Point to Point Bridge on IAP 277
We are trying to implement a point-to-point bridge between two IAP 277 such as below. 2015-10-26_134943.jpg
We have trunked Vlan 9 at the switch and the IAP and set the native Vlan to Vlan 4 for management. The customer would like to manage the IAPs and the Switches at both site using the native vlan 4.
FROM SITE A
Users on Vlan 4 at site A are able to ping Site A switch , Site A IAP 277 as well as Site B IAP 277. However the ping drops when we try to ping from USER A (Vlan 4) to the switch at Site B (also Vlan 4). As the ping is unable to reach the switch, the connection between user A (Vlan 4) and user B (Vlan 4) is also down. Note that connection between devices on VLAN 9 is fine and user A (Vlan 9) is able to ping user B (vlan 9).
FROM SITE B
User B (vlan 4) is able to ping the gateway for vlan 4 on the switch at Site B. However, User B (Vlan 4) is unable to ping Site B IAP 277. Due to this, Users at site B are unable to reach the users at Site A on Vlan 4. Note that connection between devices on VLAN 9 is fine and user B (Vlan 9) is able to ping user A (vlan 9).
Its seems that there is something wrong with the Native Vlan as I am unable to ping the switch behind the mesh Point AP. Is this something in the settings that I am overlooking?
If anyone has ran into this...any assistance would be appreciated.
Re: Point to Point Bridge on IAP 277
You might open a TAC case and send the two config files from each IAP to validate. That will likely be your fastest resolution. On the face of it, to me it reads like there is an issue with something on the SiteB switch, since at least VLAN 4 works from Site A workstation to Site A 277 to Site B 277, but NOT the other way around.
If you want to post your switch models, switch configs, and IAP configs, feel free.
Jerrod Howard
Thanks for the reply. Attached are the configs for both switches and the Master IAP. Please let me know if there is any settings that i have missed. The config at the switch is pretty straigthforward with Vlan 4 and 9 created at both switches.
I would still open a TAC case nonetheless. I will try to look at this in detail later this week. I would also characterize which clients can reach which IP addresses from their respective sides to help narrow down where the breaks occur, the switch models and firmware versions, same with the IAPs, etc as part of the case. They can work with you to narrow down options.
Jerrod Howard
Contributor II
This ever got resolved?
