Contributor I
Poor Internet connection, disabling network. Android problem?
Hi all.
I get this "Poor Internet connection" on Android devices and it's disabling network because of that and clients are complaining.
We are using Captive portal that prevents on init-role such traffic.
Just heard about this "problem" and I read about it from Internet, seems to be only Android related? It can be disabled from Android device but  clients dont know how to do that and so on.
I know I could enable this check-address to passthrought from init-role but does anyone know the address where Android deviced are checking this "poor internet connection" ?
BR,
Joakim
Community Administrator
Re: Poor Internet connection, disabling network. Android problem?
I to would love to know the answer to this, if there is a non-android solution.
My work around was changing settings on the device.
Airheads Community - The best place to Connect. Engage. and Learn.
