PopUP
Hi to all.
My question is We you can enable the Pop-Up after the authenticationif possible could help me with the procedure
Regards..
Re: PopUP
What type of authentication?
What type of popup?
Tim Cappalli | Aruba Security
Frequent Contributor II
Re: PopUP
ArubaInstant or ArubaOS (controller-based?). ClearPass Guest is used?
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Re: PopUP
I have a captive portal running ClearPass with any type of popup.
Regards
Re: PopUP
What are you trying to pop up?
Re: PopUP
I want to do is see if it is possible that when users authenticate to the network aparesca them a message if you have problems with the service or can not authenticate mark a number that I want to know if I set my ClearPass.
Is it possible?
Thanks in advance
Re: PopUP
I could set from my controller or the ClearPass ???
Thank you for your help
Re: PopUP
Do you want to display a message or notification (with a phone number) at the login page?
If you are using ClearPass Guest you should configure this on the weblogin. The login page can be customized to accommodate this.
www.securelink.nl
Re: PopUP
I want to display a message with an email address, if you can not access the wireless network send an email to an area responsible for network support. is possible??
Re: PopUP
If this is post authentication, then they've already connected to the network.
The problem with post auth "splash pages" is that you have to create a separate role and trigger the user to change roles after they are done with the page.
