Occasional Contributor I
Primary usage in IAP
Can we edit or configure more primary usage(Employee, Voice and Guest) in IAP
Re: Primary usage in IAP
No, they are predefined. What are you trying to achieve?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Custemor asking to configure the BYOD using IAP, can i define one more primary usage as BYOD
Most of the time you will be choosing the employee type, because it is the most flexible.  Voice will tag all of the packets as high priority regardless of what options you choose.  Choosing guest will give you Captive Portal Options.
Those are the only difference, with Employee giving you the most flexibility.
