Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
This thread has been viewed 92 times
  • 1.  Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
    Posted May 04, 2016 04:25 PM
    I am having an issue upgrading the OS on a Aruba 7005 controller using cpboot.
    I used the following variables:
    cpboot> setenv ipaddr 192.168.1.199  <<< Controller IP address
    cpboot> setenv netmask 255.255.255.0 <<< Controller subnet mask
    cpboot> setenv gatewayip 192.168.1.1 <<< Controller gateway IP
    cpboot> setenv serverip 192.168.1.200<<< tftp server IP address(laptop)
    cpboot> setenv ethact xlr_gmac0
    cpboot> save
    I have a laptop connected to the controller on interface ge0.
    I installed Solarwinds tftp and server bindings to 192.168.1.200.
    From the controller cpboot prompt, I can IP 192.168.1.200.
    However, I am unable to ping the default-gateway 192.168.1.1.
    From the laptop, I am able to ping the controller's IP address.
    Here are the env variables:
    cpboot> printenv
    bootargs=quiet
    bootcmd=bootf
    bootdelay=2
    baudrate=9600
    netretry=no
    stdin=serial
    stdout=serial
    stderr=serial
    wdtftp=1
    ethaddr=00:0b:86:be:95:46
    eth1addr=00:0b:86:be:95:47
    ipaddr=192.168.1.199
    netmask=255.255.255.0
    gatewayip=192.168.1.1
    serverip=192.168.1.200
    ethact=xlr_gmac0
    Here are the print results:
    cpboot> ping 192.168.1.1
    Using ge-0 device
    ping failed; host 192.168.1.1 is not alive
    cpboot> ping 192.168.1.200
    Using ge-0 device
    host 192.168.1.200 is alive
    cpboot>
    Here is error message that appears during upgrade:
    cpboot> upgrade 0 ArubaOS_70xx_6.4.4.6_54633
    AOS Upgrades with Ancillary Files images from cpboot will cause
    partition 0 and 1 to both contain the new AOS version.
    Do you wish to continue? (y or n): y
    Starting TFTP Download ...
    Using ge-0 device
    TFTP from server 192.168.1.200; our IP address is 192.168.1.199
    Filename 'ArubaOS_70xx_6.4.4.6_54633'.
    Load address: 0xa800000030000000
    Loading: T T T T T T T T T T
    Retry count exceeded; starting again
    cpboot>
    Anyone have any suggestions on how to fix issue?
  • 2.  RE: Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
    Posted May 04, 2016 11:27 PM
    what are the logs on the server? does it say, controller IP reached out to it?
  • 3.  RE: Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
    Posted May 11, 2016 05:44 AM
    T T T T T means TFTP timeouts, so your TFTP server is not responding. That is likely either a firewall issue on your laptop, or a configuration on the TFTP server software. Please try to disable your firewall (temporarily) and check the TFTP server log files.
  • 4.  RE: Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
    Posted Jun 23, 2016 11:10 AM
    Thanks for the tip about the TFTP server applications.
    Once I shutdown the firewall and reconfigured the binding settings, the tftp file transfer started working.
    I successfully loaded the 6.5.0.0 OS on both partitions and restarted the controller.
  • 5.  RE: Problem Upgrading a Aruba 7005 Controller Image Using cpboot - Retry Count exceeded; Starting Again
    Posted Feb 19, 2018 03:01 PM
    For anyone that has arrived here via google (like myself), If the 7005 is powered via POE, I noticed that the interface I was trying to ping from wasn't the one that was plugged into the switch. I promptly plugged another cable into eth3 and sure enough everything worked flawlessly.
