Occasional Contributor I
Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
Problem : I can't identify what is the problem
The context : Airwave Interface is down
Re: Problem concerning the upgrade of airwave from 8.0.8.1 to 8.2.0.1
Any ideas ?
This is an overview from AMP-8.2.0.1-upgrade.log :
Problem solved : conflict of package Openldap.
I happen too.
I don't know how to solve the problem.
How to do System is normal working ?
Please answer to me.
Hi Kim,
Can you post the AMP-8.2.0.1-upgrade.log that i can help you to identify the problem ?
in CLI :
cd var/log/upgrade/
cat AMP-8.2.0.1-upgrade.log
and post it her
