Occasional Contributor I
Problem importing plan on airwave virtualRF
Hello everyone,
I'm doing plan for wifi in the VisualRF plan standalone software because it has more option and easier to use.
Local Quickview
Version:Build Date:Java Runtime Version: VisualRF Engine Version:VisualRF Engine Build:VisualRF Engine Database:VisualRF Data Path:VisualRF Plan Static:
7.7.rc1 (build: 448)
2014-05-19 13:09 PDT
1.6.0_22
7.7.0
80766
80766
C:\Program Files (x86)\VisualRF Plan\data
80766
I'm having problem when importing the plan into airwave VisualRf. The background OR wall is misplace and they are out of "sync". I'm uploading and exemple of the problem.
I try the two way the software offer to export. No cigar.
Anyone ever had the same problem?
Is there a way to move the background image once imported in the airwave app?
Thank you very much
Regular Contributor I
Re: Problem importing plan on airwave virtualRF
what version of airwave do you use?
I think this is a browser problem with html5...
use chrome and taka a look on your plan. Chrome works better with it...
On Airwave version 8.0.4.1 or 8.0.5 I think the problem is fixed...
give kodos if it works :-)
for Airwave upgrade use on comandline the command:
amp_upgrade
Currently on airwave 8.0.4.1
Will try to import the plan on Chrome soon.
I'll give some feedback ASAP
Thank you very much for your help!
Tested with Chrome. No cigar.
I'm waiting for airwave update. Many things happening and can't do it right away.
Airwabe has been updated to 8.0.5 and the problem still happend.
We can select all the wall in same time. is there a way to moved them all as one?
I would hate to redo all building in the web version of VRF.
I still haven't found a solution.
Anyone can help?
Moderator
Suggest opening a case for this with TAC.  We've resolved several issues in the AirWave VisualRF.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
