- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
08-30-2016 03:17 AM
I have a cluster of two IAP 103. I had a problem to surf in internet, while the cabled network was working fine.
I changed a IAP 103 with a IAP 205 and now I can surf internet, when I'm connected under the IAP 205, but still unable to surf if connected under the IAP 103.
The IAP 205 is the master so IAP 103 should have the same configuration.
I don't understand why I can't surf internet with the IAP 103. Any idea?
Thanks for the help.
Best regards
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Problem with IAP 103 to surf in internet
08-30-2016 03:37 AM
The SSID that you created, is the VLAN "Network Assigned" or "Virtual Controller Assigned"?
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 03:48 AM
The ip address is network assigned and the vlan is the default one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 04:01 AM
Are clients getting the same ip addresses when they attach to the IAP-103? Does it have the same configuration as the 215?
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 04:10 AM
The client maintain always the same ip address under IAP 103 and IAP 205. In every case I can ping the gateway, but when I'm under the IAP 103 I can't ping for example 8.8.8.8, insteed under IAP 105 I can do it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 04:11 AM
Connecting in ssh to the IAP 103 I can ping 8.8.8.8, but not from the clients of this IAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 04:15 AM
Are the two IAPs in the same cluster?
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 05:22 AM
Yes, same cluster.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 05:38 AM
Do you have an internet router? Why would it block access from one IAP and not another. Do the IAPs have statically assigned addresses? If yes, maybe the subnet mask and default gateway are not correct on the IAP that cannot access the internet.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-30-2016 05:46 AM
Yes, we have an internet router. We have statip ip address on the IAP and I verify many times the mask and gateway configuration, that is the same of the IAP 205. I also tried to assign the ip address of the IAP 205 to the IAP 103 but it still doesn't access to internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
