- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problems with iphone ios9 and aruba IAP103
12-19-2016 01:48 AM
I have 3 aruba iap103's. I have 3 apple devices and 1 android device. With the iphone i cannot stream netflix to the chromecast. With the android i can.
Youtube is no problem but with netflix i do not see the stream option on the iphone.
Does anyone have a solution? I have installed the latest firmware that is available via update.
Danny
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Problems with iphone ios9 and aruba IAP103
12-19-2016 01:57 AM
If you install the Chromecast app on the iPhone, can you setup the actual Chromecast? What's the version of Netflix on the iPhone?
HPE Aruba ERT (EMEA) ACMP
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 02:10 AM
Hi yes i can install the chromecast. netflix is version 9.0.3(871) 4.3.4-360
Youtube streaming is working fine.
danny
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 02:33 AM
Do you even see the Chromecast icon on the Netflix app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 02:51 AM
No i do not see that in netflix
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 03:04 AM
Is "Guest" mode enabled on your Chromecast? If not, then enable it, wait a few seconds and you'll probably see the Chromecast icon appear in the Netflix application.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 04:14 AM
Ok i will try this. Will let you know if this was the solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 06:46 AM
I can see the sign now but it cannot connect.
Danny
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-19-2016 07:11 AM
That's because in guest mode, you are connecting adhoc to the Chromecast. In your Chromecast setup, in the Guest Mode dialogue, you'll see you have different PIN than your "normal" Chromecast mode.
Don't forget that in Guest Mode, any device in with connectivity to the Chromecast can connect adhoc if they know the Guest PIN.
From the Aruba IAP side, I assume your iPhones are in the the same SSID and VLAN as the Chromecast and you have enabled airgroup services, correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-21-2016 04:22 PM
If you haven't done so already, make sure you check all the DLNA protocols in airgroup.
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
