Proximity between Aruba APs w/directional antennas
is there a good rule of thumb when installing APs back to back (with directional antennas) in terms of the minimum distance between the two?  See photo below.  Any other recommendations?
Re: Proximity between Aruba APs w/directional antennas
Which model antennas? Generally 1-2m is sufficient for sector antennas.
Jerrod Howard
