Question regarding MIMO and client density
I keep reading that in order to utilize a 3x3:3 AP, you would need a 3x3 client.
What I'm trying to understand if this is a misconception. While I understand that throughput may be limited to 2 streams in a 2x2 client, couldn't a 3x3 configuration support more clients?
I'm thinking something along the lines of the following
Client 1 could utilize Tx radios 1, 2 and client 2 could utilize Tx radios 2 and 3.
Can someone verify this is the case?
Re: Question regarding MIMO and client density
802.11ac Wave 2 will haver his functionality
http://en.m.wikipedia.org/wiki/Multi-user_MIMO
Thank you
Victor Fabian
Lead Mobility Architect
