Frequent Contributor II
Quick walk through
I have 2 instant access points, i would like to have the second one mesh up but not re-broadcast the ssid, i want to use it as a bridge and use its ethernet ports (its a 205H) to connect a hardlined machine.
could someone give me a quick walk through?
thanks!
#AirheadsMobile
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
Re: Quick walk through
Maybe this might work if you create different zones and only send out the ssid in one zone and use the mesh in instant. But I have not yet build this setup
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
You will need to broadcast at least one SSID on a Instant Mesh AP, as the AP will consider itself unconfigured as it sees no SSID configured and wipe the config.
See: http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Instant-27x-AP-with-Ethernet-Bridging/m-p/262940 for a similar question.
