Regular Contributor I
RAP3 and 3G uplink problem
[ Edited ]
I have a little issue with a RAP3 (used as an IAP) and 3G uplink. Here is the situation :
- Configuration is ok for 3G uplink
- 3G is working
- IAP version is 6.2.1.0-3.4.0.1_39461
But the only way to make 3G uplink up is to boot the RAP3 with eth0 connected to the network. In this case, 3G uplink is ok. If I boot the RAP3 only with the 3G key, the uplink never goes up.
Any idea about this ?
Dimitri
Re: RAP3 and 3G uplink problem
Problem solved. I have needed to enforce uplink for 3G/4G and now it's working as attended.
Dimitri
[ Edited ]
EDIT , unneeded post of myself, found information here in forum.
