Contributor I
RAP3 configuration issues with Huawei E122 USB.
I'm trying to configure a RAP3 using a Huawei E122 USB dongle provided by Three (ISP) in Ireland.
I managed to find the configuration guide but it requires me to enter a number of parameters that I do not have access to.
First of all neither Ireland or Three is available in the dropdown menu as country or ISP.
Additionally I don't have such details as the TTY-port, modem initialisation parameter etc.
I'm wondering if these are actually all required as the dongle is pretty much plug 'n play with other devices.
Can anyone shed some light on this?
Frequent Contributor I
Re: RAP3 configuration issues with Huawei E122 USB.
This modem should work however you have to google all needed parameters. You can check them as well with any modern Linux desktop distri as well. Try with kali linux for example. In the logs you should see modswitch, usb dev, driver and tty device.
HTH,
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
Contributor I
Thanks for the reply.
So these paramaters are specific to the hardware and not to the ISP I'm using?
Definitely they are.
EvertBopp,
Did you see the article here?  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/What-are-the-supported-4G-USB-modems-and-how-do-I-configure-them-as-uplink-in-Aruba-Instant
It might not be necessary to enter ALL the options if some can be autodetected.  Would you like to post your screenshot of 3g/4g status from the IAP if available?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
