Radio power levels
Is there a way to control both radio's power on an IAP-225?  I set one setting in the GUI for min/max tx power, but that's it.  I set the min/max to 15dBm which seems to only apply to 5GHz.  When I issue "show ap bss-table", 2.4 is operating at 21dBM.  Any thoughts?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Radio power levels
MASTER-MESH-PORTAL# show  arm config
Minimum Transmit Power            :9
Maximum Transmit Power            :18
Band Steering Mode       :prefer-5ghz
Client Aware             :enable
Scanning                 :enable
Wide Channel Bands       :5ghz
80Mhz Support            :disable
Air Time Fairness Mode   :preferred-access
Client Match             :enable
CM NB Matching Percent   :75
CM Calculating Interval  :30
CM SLB Threshold         :2
CM SLB Balancing Mode    :channel based
CM Max Request           :5
CM Max Adoption          :5
CM Debug Level           :error
Custom Channels          :Yes
2.4 GHz Channels
MASTER-MESH-PORTAL# show ap bss-table
Aruba AP BSS Table
bss                ess      port  ip           phy   type  ch/EIRP/max-EIRP  cur-cl  ap name             in-t(s)  tot-t
6c:f3:7f:b7:e4:d2  TULOABE  ?/?   192.168.1.3  a-HT  ap    100+/18/22        1       MASTER-MESH-PORTAL  0        21h:12m:36s
6c:f3:7f:b7:e4:c2  TULOABE  ?/?   192.168.1.3  g-HT  ap    11/18/21          1       MASTER-MESH-PORTAL  0        21h:12m:34s
 What version of IAP Os are you running ? I am running the latest 4.1.1.1 and it looks like it works
Thank you
Victor Fabian
Lead Mobility Architect
4.1.1.1 as well.
I set my 2.4 valid channels to 1 only and it's stuck on 6 so I may have a bigger issue here.  Going to reboot the IAP to see if that helps.  Even if it does fix the issue of 2.4 and 5 power levels not matching, is it possible to independantly control their power?
Maybe a 225 issue ? I am using an IAP135
Thank you
Victor Fabian
Unfortunately you can't set that individually , Feature Request ?
Thank you
Victor Fabian
Thanks for the info, Victor.
