Reboot Reason: AP rebooted mesh link BAD. rebooting mesh point by sapd
did anyone observe this strange behaviour?
my AP mesh point continue to reboot every 20 minutes
IAP-175 OS version: 6.2.1.0-3.3.0.2_38733
Thank you
Re: Reboot Reason: AP rebooted mesh link BAD. rebooting mesh point by sapd
Usually this happens due to poor RF connection quality from the mesh portal to the mesh point. Could I understand if this is a new AP that got installed or has it been working for a while and just started to have this problem?
Sent from my iPhone
Contributor II
run the comand show version
aruba-ap# show version
ArubaOS (MODEL: 105), Version 6.3.1.1-4.0.0.1
Website: http://www.arubanetworks.com
Copyright (c) 2002-2013, Aruba Networks, Inc.
Compiled on 2013-11-26 at 12:32:36 PST (build 41049) by p4build
AP uptime is 5 days 18 hours 48 minutes 51 seconds
Reboot Time and Cause: AP rebooted Tue Jan 7 20:56:34 UTC 2014; Image Upgrade Successful
aruba-ap#
It has been working good for a while....so i can't understand the reason of this behavour.
Mesh portal and mesh point are 50 meters and full visible to each other.
Yes i guess for some reason there is poor RF connection.
do you know if there is something i can setup to mitigate this?
You probably need to work with support, or have someone take a look at your setup.  If there is a hidden source of interference or if the antennas managed to be come unaligned, it could create the issues you mention.
Thank you ,
about alignement it's not an issue because i  use a couple of omni 5Ghz.
about interference...is it capable or not IAP 175 to change channel if detects a source of interference?
could you please tell me some smart commang to troubleshoot it?
i used to work with Aruba MSR and trobleshooting with IAP i found it very difficult.
thank you
Let me repeat the phenomenon:
mesh point (IAP-175) running 38733 build, rebooted every 20 minutes because of mesh link failure. And the mesh portal is IAP-105 running 41049. Right?
Then let 's check:
1. check the antenna connectivity
2. run below comands on portal:
    show running-configuration
    show ap-env
    It is better, if following comands can be run right after IAP175 rebooting. If not, the outputs of these commands are also helpful
    show ap mesh neighbours
    show log debug
    show ap arm history
    show ap arm rf-summary
3. run below commands on that IAP-175, if possible,
    show ap-env
mesh point and mesh portal are both IAP-175, and since this morning, i upgraded both to:
6.3.1.2-4.0.0.2_41506
but every 20-15 min ore sometimes more 40 min the mesh point reboots. now it's not so regular.
I suspect DFS issue. Is there a way to turn it off (for a while) my regulatory domain is Europe.
that's AP arm histor on mesh portal:
Interface :wifi0
ARM History
Time of Change Old Channel New Channel Old Power New Power Reason
2014-01-14 13:30:47 116+ 124+ 27 27 M
2014-01-14 13:11:29 100+ 116+ 27 27 R
2014-01-14 13:11:18 132+ 100+ 27 27 R
2014-01-14 13:10:47 108+ 132+ 27 27 R
2014-01-14 13:08:09 116+ 108+ 27 27 R
2014-01-14 13:00:36 124+ 116+ 27 27 R
2014-01-14 12:34:57 116+ 124+ 27 27 R
2014-01-14 12:06:54 100+ 116+ 27 27 R
2014-01-14 12:06:16 100+ 100+ Max 27 P-
Mesh: portal:
sh ap mesh neighbours
Neighbor list
MAC Portal Channel Age Hops Cost Relation Flags RSSI Rate Tx/Rx A-Req A-Resp A-Fail HT-Details Cluster ID
d8:c7:c8:02:47:f9 d8:c7:c8:02:46:98 116+ 1 1 7.00 C 9m:39s HLK 49 270/270 1 1 0 HT-40MHzsgi-2ss a2fdabcb9231957da75a0d509eb8d8b
after a while...
sh log wireless
Jan 14 15:31:31 sapd[1121]: <404076> <WARN> |AP wisper_montefiore_comune_ap2@10.41.9.3 sapd| AM d8:c7:c8:02:46:98: Radar detected on interface wifi0, channel 116, typeid 38
after a while...
sh ap mesh link
Neighbor list
d8:c7:c8:02:47:f9 d8:c7:c8:02:46:98 100+ 0 1 7.00 C 3m:43s HLK 54 300/300 1 1 0 HT-40MHzsgi-2ss a2fdabcb9231957da75a0d509eb8d8b
Jan 14 15:58:42 sapd[1121]: <404088> <WARN> |AP wisper_montefiore_comune_ap2@10.41.9.3 sapd| AM d8:c7:c8:02:46:98: ARM HT Radar Detected Trigger Current Channel old 116+ new 100+/9
Jan 14 16:18:32 sapd[1121]: <404076> <WARN> |AP wisper_montefiore_comune_ap2@10.41.9.3 sapd| AM d8:c7:c8:02:46:98: Radar detected on interface wifi0, channel 100, typeid 33
Jan 14 16:18:32 sapd[1121]: <404088> <WARN> |AP wisper_montefiore_comune_ap2@10.41.9.3 sapd| AM d8:c7:c8:02:46:98: ARM HT Radar Detected Trigger Current Channel old 100+ new 116+/9
and now...no connectivity. what's happening?
ARM History
2014-01-14 16:18:32 100+ 116+ 27 27 R
2014-01-14 15:58:42 116+ 100+ 27 27 R
2014-01-14 15:29:28 116+ 116+ Max 27 P-
It looks like you are using DFS channels and are encountering Radar.  What is your regulatory domain?
