Valued Contributor I
Recent IAP Firmware Releases
This post outlines high level information about recent IAP firmware releases.  Hopefully it will aid you in determining what version you should be running and help delineate the differences between versions.
Info about new versions of IAP SW will be added to this post as they are released.  Subscribe to this post to be alerted when new versions of code are released.
Please contact Aruba Support before upgrading if you have any questions.  A valid support account is needed to access the firmware files and release notes.  The release notes are the definitive source of information about a release and should always be read before upgrading.
Currently, IAP images are posted to the TAC site, under SW Downloads first followed by posting to the Cloud based upgrade server 4 - 6 weeks later.  Dell branded IAPs typically see the SW upgrade 4 - 6 weeks after the Aruba image is released.
Instant 3.1 (6.1.3.4-3.1.0.0) Released Sept. 17, 2012
Release highlights are listed below.  Check the Release Notes for a complete list of new features.
  • Spectrum Analysis.
  • Layer-3 Roaming
  • USB and PPPoE uplink
  • Uplink failover
  • Dynamic Multicast Optimization
  • Media Classification for Lync and FaceTime
  • 4G Support for RAP-3WN in Instant mode
Instant v. 3.2 (6.2.0.0-3.2.0.0) Released March 8, 2013
  • Authentication Survivability (With ClearPass 6.0.2+)
  • Distributed Airgroup (With ClearPass 6.0+ as integrated release)
  • Wifi Uplink
  • 802.1X authentication for wired users
  • WISPr Authentication
  • GVRP based vlan propagation (With MAS 7.2)
  • IPSec fast failover
  • Mixed authentication modes per SSID
  • VLAN Pooling
  • Daylight Savings Time
Instant v. 3.3 (6.2.1.0-3.3.0.0) Released March 8, 2013
  • RAP-155 support
  • New USB modems
  • Spectrum Load Balancing
  • WMM
  • Staggered SW upgrades (update now and reboot later)
  • Dual uplinks
  • CLI officially supported with CLI reference guide
  • Minor UI reorganization
  • Ability to disable an SSID rather than deleting it
  • Redirect to external captive portal via HTTPS
Re: Recent IAP Firmware Releases
Instant v. 3.3.0.2 (6.2.1.0-3.3.0.2) Released June 24, 2013
This is a patch release.  No new features are included.  Fix highlights are listed below.  Check the Release Notes for  complete desctiptions of the fixes.
Fix Summary:
  • Regulatory Domain support for RAP-155 in EU.
  • Three Mesh related issues
  • Incorrect status shown for unathenticated clients.
  • Client connectivity issue when client is on a Slave IAP and Dynamic Radius Proxy is enabled.  Problem caused by Radius packets tagged with incorrect VLAN ID.
Instant 3.4 (6.2.1.0-3.4.0.0) Released July 22, 2013
  • L2TPv3 tunnelling support
  • Lawful intercept capability (CALEA)
  • Dynamic CPU management
  • Regular expression based DHCP option role and VLAN derivation
  • Unnumbered PPPoE interface support
  • Reconnect user on VPN failover to force client DHCP refresh.
  • Connectivity summary on Instant UI
Instant v. 3.4.0.1 (6.2.1.0-3.4.0.1) Released August 21, 2013
This is a patch release with minor feature additions.  Fix highlights are listed below.  Check the Release Notes for  complete desctiptions
New Features:
-Support for Huawei HWD12 modem.
-Minor enhancements to the WPA PSK configuration
Fix Summary:
  • Two random reboot issue occuring in v.3.3
  • Authentication issue with .1x when Radius Proxy is enabled in v.3.2
  • Unable to connect to the IAP and traffic fowarding issue when Radius Proxy is enabled in v.3.3
  • others...........
Instant v. 3.4.0.2 (6.2.1.0-3.4.0.2) Released September 20, 2013
New Features:
-Support for the Novatel Wireless U679 (for RAP-3WNP only) and Sierra Wireless 320U modem
Fix Summary:
  • Two authentication issues
  • Three Hotspot 2.0 issues
  • One L2TPV3 issue
  • One Mesh issue
  • One SNMP issue
  • Release Notes and SW can be downloaded here:
Instant v. 3.4.0.3 (6.2.1.0-3.4.0.3) Released October 14, 2013
This is a patch release with no new features.  Fix highlights are listed below.  Check the Release Notes for complete descriptions.
Fix Summary:
  • Authentication: Radius authentication failed for clients connecting to a Member IAP.
  • IAP-VPN: Two issues with VPN failover with IAPs running v.3.4.x.x.
  • Mesh: Process crash on the Mesh Portal. Found in v.3.3.0.0 and later.
  • L3 Roaming: Two issues.
  • SNMP: VC does not respond to queries coming in from the Ethernet port.
  • DHCP issue with Windows 2012 DHCP Server when DHCP Failover feature is enabled.
Instant 4.0(6.3.1.1-4.0.0.0) Released November 18, 2013
Instant v.4.0 is a major release with many new features. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Platform:
  • IAP-224/225
  • IAP-114/115
  • LACP
  • STP for multi-port APs
  • Telnet - re-enabled
Wireless:
  • 802.11ac
  • Distributed Client-Match
  • OKC
  • 802.11r
Security:
  • Bandwidth contracts - Asymmetric bandwidth contracts per-role
Guest Captive Portal:
  • Multiple external CP profiles - per-role
  • Custom certificates for captive portal
  • Internal splash page customization - logo
  • Guest-manager UI
  • Domain-based ACLs
Services:
  • Analytics & Location Engine Integration
  • Palo Alto Network Firewall integration
  • AirGroup enhancements
Zero-touch provisioning:
  • HTTP proxy for cloud-upgrade
  • DNS-based AirWave discovery
Management:
  • Aruba Central sign-up
  • View-only login
  • Certificate-based auth between IAP and AMP
IAP-VPN:
  • Centralized-L3 mode, with DHCP relay
  • GRE outside IPSec for guest DMZ
Instant 4.0.0.1 (6.3.1.1-4.0.0.1) Released Dec. 2, 2013
This is a minor release with a bug fix. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
  • Regulatory Domain changes. Previously domains were: -IL, -JP, -US, and –RW.  New domains are: -US and –RW.
  • Wired port profile: Unable to create a wired port profile via the WebUI. Fixed in 4.0.0.1.
Instant 4.0.0.2 (6.3.1.1-4.0.0.2) Released Jan. 2, 2014
This is a minor release with three enhancements and several bug fixes. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Enhancements:
  • Support for automatic negotiation support for authentication between IAP and AirWave.
  • PPoE Configuration – can configure up to 80 characters for username, service name, password, and the secret key for CHAP auth.
  • Support for VPN tunnel states and statistics reporting from IAP
Bug Fixes:
  • ARM – radios were continuously resetting in the presence of certain interfering devices.
  • Firewall – When Drop Bad Arp was enabled clients could not connect to the network.
  • IDS – A syslog message was not getting generated when a Rogue AP was detected.
  • SNMP- ColdStart and WarmStart traps were not being generated.
  • Uplink Mgmt – Unable to configure the uplink Vlan through the CLI
  • VPN cfg – DHCP packets were dropped resulting in the VPN tunnel dropping.
  • WLAN cfg – IAP-93 broadcasting SSID in the wrong band.
Instant 4.0.0.3 (6.3.1.1-4.0.0.3) Released Jan. 20, 2014
This is a minor release with two enhancements and several bug fixes. Release highlights are listed below.  Check the Release Notes for a complete list of new features.
Enhancements:
  • Change in the Timeout Duration for an Inactive User
  • IAP-VPN Scalability Enhancements
Bug Fixes:
  • Authentication –  Allowed invalid certificates to be uploaded without error.
                                 -- The .pem cert was not displayed in the output of "show cert all"
  • Firewall – DSCP mapping value of the client was not copied to the outer header.
                      -- When the 0.0.0.0 routhing profile was defined the SA was translated incorrectly.
  • AP Config – Master IAP did not apply sys location config to slave IAPs joining the cluster.
  • WiFi Driver- Latency
