Roaming problems with IAP and WindowsCE devices
Hi
I'm experiencing roaming slow connectivity with Windows CE 6 devices under Aruba instant IAP93 access points.
We have done several installations in logistics and this the first time we see this.
The roaming is randomly very slow and we loose about 10 pings before the client radio connect
When this occurs we do have different type of mesages: here are examples
: <541004>  |AP CHAMBLYAP5@192.168.18.45 cli|  recv_sta_online: receive station msg, mac-00:23:68:e7:f1:e7 bssid-6c:f3:7f:0f:e0:d3 ssid-terMLogistikChamblyAFDB.
Dec 18 14:20:17  cli[1544]: <541004>  |AP CHAMBLYAP5@192.168.18.45 cli|  recv_stm_sta_update: receive station msg, mac-00:23:68:e7:f1:e7 bssid-6c:f3:7f:0f:e0:d3 ssid-terMLogistikChamblyAFDB.
Dec 18 14:20:17  stm[1552]: recv_radius_acct_multi_session_id: 14594: got mac='00:23:68:e7:f1:e7', name='', start_time='1418912362 (Thu Dec 18 14:19:22 2014 )'
Dec 18 14:20:17  stm[1552]: stm_start_acct_for_post_1xauth_user: 14635: ip not ready for sta '00:23:68:e7:f1:e7'
Dec 18 14:20:17  sapd[1548]: sapd_proc_stm_reset_key: Got STM Reset key bss=6c:f3:7f:0f:e0:d3 mac=00:23:68:e7:f1:e7, idx=0
Dec 18 14:20:17  stm[1552]: wpa2_encrypt_key() called
Dec 18 14:20:17  stm[1552]: <132093>  |AP CHAMBLYAP5@192.168.18.45 stm|  WPA2 Key message 4 from Station 00:23:68:e7:f1:e7 6c:f3:7f:0f:e0:d3 CHAMBLYAP5 did not match the replay counter 01 vs 02
Dec 18 14:20:17  stm[1552]: <132093>  |AP CHAMBLYAP5@192.168.18.45 stm|  WPA2 Key message 4 from Station 00:23:68:e7:f1:e7 6c:f3:7f:0f:e0:d3 CHAMBLYAP5 did not match the replay counter 02 vs 03
Dec 18 14:20:18  stm[1552]: wpa2_encrypt_key() called
Dec 18 14:20:24  stm[1552]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='00:23:68:e7:f1:e7'
Dec 18 14:20:24  cli[1544]: <541004>  |AP CHAMBLYAP5@192.168.18.45 cli|  recv_sta_offline: receive station msg, mac-00:23:68:e7:f1:e7 bssid-00:00:00:00:63:6c ssid-.
Dec 18 14:20:24  sapd[1548]: sapd_proc_stm_reset_key: Got STM Reset key bss=6c:f3:7f:0f:e0:d3 mac=00:23:68:e7:f1:e7, idx=0
Dec 18 14:20:26  stm[1552]: VLAN_HIGHER_PRECEDENCE_THAN_STORED: 1022: vlan_rule_index=ff, sap_sta->vlanhow=ff, precedence_result=1
Dec 18 14:20:26  stm[1552]: __HIGHER_PRECEDENCE_COMPARE: 999: matched_rule_index=37fff, sap_sta->acl_rule_index=0, precedence_result=1
Dec 18 14:20:26  stm[1552]: stm_send_sta_update: Sending sta update msg to CLI0, mac='00:23:68:e7:f1:e7'
Dec 18 14:20:26  cli[1544]: <541004>  |AP CHAMBLYAP5@192.168.18.45 cli|  recv_sta_online: receive station msg, mac-00:23:68:e7:f1:e7 bssid-6c:f3:7f:0f:e0:d3 ssid-terMLogistikChamblyAFDB.
Dec 18 14:20:26  cli[1544]: <541004>  |AP CHAMBLYAP5@192.168.18.45 cli|  recv_stm_sta_update: receive station msg, mac-00:23:68:e7:f1:e7 bssid-6c:f3:7f:0f:e0:d3 ssid-terMLogistikChamblyAFDB.
Dec 18 14:20:26  stm[1552]: recv_radius_acct_multi_session_id: 14594: got mac='00:23:68:e7:f1:e7', name='', start_time='1418912362 (Thu Dec 18 14:19:22 2014 )'
Dec 18 14:20:26  stm[1552]: stm_start_acct_for_post_1xauth_user: 14635: ip not ready for sta '00:23:68:e7:f1:e7'
Dec 18 14:20:26  sapd[1548]: sapd_proc_stm_reset_key: Got STM Reset key bss=6c:f3:7f:0f:e0:d3 mac=00:23:68:e7:f1:e7, idx=0
Dec 18 14:20:26  stm[1552]: wpa2_encrypt_key() called
Dec 18 14:20:26  stm[1552]: <132093>  |AP CHAMBLYAP5@192.168.18.45 stm|  WPA2 Key message 4 from Station 00:23:68:e7:f1:e7 6c:f3:7f:0f:e0:d3 CHAMBLYAP5 did not match the replay counter 01 vs 02
Dec 18 14:20:26  stm[1552]: <132093>  |AP CHAMBLYAP5@192.168.18.45 stm|  WPA2 Key message 4 from Station 00:23:68:e7:f1:e7 6c:f3:7f:0f:e0:d3 CHAMBLYAP5 did not match the replay counter 02 vs 03
Dec 18 14:20:27
I've read in this forum people having experienced this replay counter message and the suggestion was to modify the WPA intervalle timeout.
Unfortunately, i cant't find this option on my instant version 6.3.1.8-4.0.0.8_46401
As this is a logistic sitewith high availability needs, i can't make tests as i want.
Can any one help and give any comments suggestions to get better roaming performance??
thx
Elie
Re: Roaming problems with IAP and WindowsCE devices
Hi
For anyone having experienced this problem, be careful when you upgrade the IAP firmware; I had a corrupted config file and corrupted OS;
Downgrading to version 6.2 and making again the config from zero despite reloading solved my pb.
Thanks to those who made attention at this post.
Elie
soundofthunder wrote:
Hi
Dec 18 14:20:27
thx
Elie
