SNMP - Help with MIB to monitor the clients of my IAP in VC.
Dear,
I need the Instant MIB, I could only find the: ARUBA-MGMT-MIB.mib // ARUBA-MIB.mib // ARUBA-TC.mib this way, I can not follow the connected clients in my ZABBIX via snmp, can anyone help?
My WLC is an Aruba Virtual Controller (VC).
aiClientTableEntry
aiClientMACAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.1
aiClientWlanMACAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.2
aiClientIPAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.3
aiClientAPIPAddress1.3.6.1.4.1.14823.2.3.3.1.2.4.1.4
aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.5
aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.6
aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.7
aiClientRxDataFrames1.3.6.1.4.1.14823.2.3.3.1.2.4.1.8
aiClientTxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.9
aiClientRxRetries1.3.6.1.4.1.14823.2.3.3.1.2.4.1.10
aiClientTxRate1.3.6.1.4.1.14823.2.3.3.1.2.4.1.11
aiClientRxDataFrames1.3.6.1.4.1.14823.2.3.3.1.2.4.1.12
aiClientRxDataBytes1.3.6.1.4.1.14823.2.3.3.1.2.4.1.13
aiClientRxRetries1.3.6.1.4.1.14823.2.3.3.1.2.4.1.14
aiClientRxRate1.3.6.1.4.1.14823.2.3.3.1.2.4.1.15
aiClientUptime
1.2.4.1.16
snmpwalk -v 2c -c snmp + IP
SNMPv2-MIB::sysDescr.0 = STRING: ArubaOS (MODEL: 103), Version 6.5.2.0-6.5.2.0
SNMPv2-MIB::sysObjectID.0 = OID: ARUBA-MIB::apProducts.69
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (974054) 2:42:20.54
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: f0:5c:19:cd:17:ac
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 72
IF-MIB::ifNumber.0 = INTEGER: 6
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.50 = INTEGER: 50
IF-MIB::ifIndex.70 = INTEGER: 70
IF-MIB::ifIndex.90 = INTEGER: 90
IF-MIB::ifIndex.91 = INTEGER: 91
IF-MIB::ifIndex.500 = INTEGER: 500
IF-MIB::ifDescr.1 = STRING: eth0
IF-MIB::ifDescr.50 = STRING: radio0_ssid_id0
IF-MIB::ifDescr.70 = STRING: radio1_ssid_id0
IF-MIB::ifDescr.90 = STRING: gre0
IF-MIB::ifDescr.91 = STRING: gre1
IF-MIB::ifDescr.500 = STRING: BR0
IF-MIB::ifType.1 = INTEGER: gigabitEthernet(117)
Re: SNMP - Help with MIB to monitor the clients of my IAP in VC.
Im having the same issue with LibreNMS ...we need the correct OID.
Please see the attached MIB reference guide to see what you are looking for.  This guide is no longer published, as the descriptions are in the mibs themselves.
Hi Colin,
Do you know why eth0 and eth1 report bogus SNMP data?
for example snmpwalk -
Port eth0: eth0 (1 / #20549) VLAN == ifType eth0bps(834.510Tbps/43.320Tbps)bytes(13.160PB/699.380TB)pkts(164.930Gpps/42.980Gpps)
any way to fix this?
I do not know.  You might want to open a TAC case to get those questions answered.
Gentlemen, Even downloading the WLSX MIBS, I can not get the number of users associated with my antenna. Another important point is that the Time and Bytes values are not correct.
Gentlemen,
I used the reference guide as requested (6.2.0.0-3.2), however, I still have no access to snmps calls, and according to the image below, I already have all the mibs on my server, can you help me?
